My question is: "In Mastercam, how do you get a smaller bit to follow the resulting cutout stock of the previous operation?" I do not want to follow the previous toolpath, or the geometry that the previous tool followed. What I want to do is have the smaller bit follow the "resulting stock" of the previous operation.
What I want to do is cut out letters (like the attached file illustrates) out of plywood with a 1/4" compression bit (easy enough). Then use a smaller diameter sanding bit (1/8") to sand the edges of the resulting stock while the stock is still on the table.
Thanks for your help,
Mike
- Anyone have some 1.5" or 2" 4130 chromoly round stock? Need some dimple dies
- LinuxCnc "Step Time" "Step Space" "Direction Hold" "Direction Setup" values??
- Drive constantly "Recovering from follow error or from disabled state"
- Problem- X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
- Making brackets; bending 1/4" x 3" aluminum flat stock
